wisecleaner_admin Posted August 31, 2020 Report Posted August 31, 2020 If you receive the above error message, don't worry! Please try the following method to fix the issue of "You are possibly a victim of pirated license key". [Part One] Editing and Overwriting 1. If Wise Care 365 is running, please close it first. 2. Open the folder C:\Windows\System32\drivers\etc\ 3. Copy the file "hosts" to Desktop. The hosts file has no extension. It CAN NOT be opened by double clicking. Right click on the hosts file and then click Properties and you can see a description of the file, just hosts. 4. Use Notepad to open the "hosts" file, delete contents about wisecleaner, and save the file. 5. Copy this new "hosts" file to C:\Windows\System32\drivers\etc\, overwrite the old one. 6. Run Wise Care 365. [Part Two] Verification After editing, you can do the following step to verify if the host file is right. 1. Press Windows logo key + R to open the run window. 2. Type cmd and click on the OK button. It will open the Command Prompt. 3. Type the following command and press Enter. ping reg.wisecleaner.com If the IP address you see is 127.0.0.1, it means you did not edit or overwrite the hosts file correctly. Please refer to the above steps or video carefully again. If the above method doesn't solve the issue, please contact [email protected] to seek more help.
