mustafa Posted September 9, 2013 Report Share Posted September 9, 2013 masa üstü simgeleri çok geç açılıyor. Yaklaşık 145 saniyeyi buluyor. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 510 MB CPU: Intel® Pentium® D CPU 3.00GHz Drive Info: C: 78,11 GB D: 70,92 GB Internet Explorer: 8.0 Lizaamign and RodgerNit 2 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 10, 2013 Report Share Posted September 10, 2013 Do you means that you take a long time to log on system? If yes, try following steps: 1, Run Wise Care 365 to clean junk files. Run Wise Care 365----System Tuneup---System Optimizer, optimize your system. Run Wise Care 365----System Tuneup---Startup Manager, set OFF all useless startup programs and services Run Wise Care 365----System Tuneup---Context Menu, set OFF all useless context menu. 2, Add your physical memory to 2 GB at least. 3, If you can not add your physical memory, run Wise Memory Optimizer to free up more memory for other programs. 4, If you need to install an anti-virus software, please install Microsoft Security Essentials. Or, you can run Wise PC 1stAid, click the 11th icon (the last one) to disable all extensions and third-party services. Link to comment Share on other sites More sharing options...
