steventuck Posted August 23, 2013 Report Posted August 23, 2013 The last problem I had with Itunes and registry problems was fixed by your emailed solution. Now when i try to burn a disck it says, "Disk burner or software not found. I downloaded the imgsoftware, still no detection. Sony Vaio is only 2 years old.
april Posted August 23, 2013 Report Posted August 23, 2013 1. When PC starts, if the power led is on? If not, maybe it's bad contact or the device is broken. 2. If the power led is on, please try to run disk which contains data and check if it can run normally. While If can not run normally, probably the laser head is broken. 3. If it can run disks with data normally, please uninstall and re-install burning software, or change to another burning software. Thanks. steventuck 1
steventuck Posted August 24, 2013 Author Report Posted August 24, 2013 What are my options now that I discovered my laser is broken?
Config Posted August 26, 2013 Report Posted August 26, 2013 Plz try this: To work around this problem, exit Windows Media Player before you insert the disc. Or, if the audio device is not enabled, use the Sound item in Control Panel to enable the audio device. To enable the audio device, follow these steps: Click Start, click Control Panel, and then double-click Sound. On the Playback tab, right-click in the blank area under Select a playback device below to modify its settings, and then select Show Disabled Devices. Right-click an audio device, and then click Enable.
