Posted
Which product did you use? Wise Program Uninstaller?
Do you means the wise program uninstaller doesn't list all programs, only a few?
The current version of wise program uninstaller only list the programs which are listed in Control Panel / Uninstall a program
In Windows 10 system, All Settings / System / App & features, it lists all apps include Windows built-in apps, such as Mail / Edge / Movies & TV..., but you can't uninstall them. The uninstall button is grey. (You can't see these Windows built-in apps in Control Panel / Uninstall a program)
Posted
Yes i'm using Wise Program Uninstaller, the problem is that in Control Panel/Uninstall a program  i've more program in list (~50 programs), when open wise uninstaller i've only a few program in list (only 13 programs)
Posted
Thanks for the responding.
I checked the Wise Program Uninstaller 1.81.96, it was working well. It list all installed programs and installed updates (except Windows system security updates). please view the attachment.
Which version do you use? Can you give me a screenshot?
Posted
There is a possible reason, when WPU starts loading the installed programs list, occurs an unknown issue, the loading was forced to stop. So, you only see few programs.
Please export the installed programs list and send to us. We will check it again.
Follow the steps to export the registry items:
1, press Win Key + R,
2, enter regedit in Run window.
3, expand HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall, right click it and click Export
4, expand HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall, right click it and click Export
