skumar00ae Posted August 22, 2013 Report Posted August 22, 2013 My system DELL INSPIRON N411Z Intel core i3-2350M [email protected] using Windows7 Home Basic.While staring the system Iam getting one messege that Edit window boot options for windows7 path/windows/system32/winload.exe partition 3 hard disk7f28300 [ /no execute=optin ] press enter to starting the windows .How i rectify this error Operating system:Windows 7 Home Basic (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3983 MB CPU: Intel® Core i3-2350M CPU @ 2.30GHz Drive Info: C: 230.47 GB E: 215.65 GB Internet Explorer: 9.0
WiseCleaner Posted September 6, 2013 Report Posted September 6, 2013 Do you have installed two OS, Win 7 and XP?
skumar00ae Posted September 8, 2013 Author Report Posted September 8, 2013 No, I installed OS win7 only.
wisecleaner_admin Posted September 9, 2013 Report Posted September 9, 2013 Run Wise JetSearch to search boot.ini If you can find it then send it to us.
skumar00ae Posted September 10, 2013 Author Report Posted September 10, 2013 C:/Users/Administrator/AppData/Roaming/Dell/MusicStage/1_6_225_0
wisecleaner_admin Posted September 11, 2013 Report Posted September 11, 2013 You means that you have found the file "boot.ini" in your computer? Like the snapshot If yes, please send the file "boot.ini" to us.
april Posted September 13, 2013 Report Posted September 13, 2013 Did you find "boot.ini" through Wise Jet Search? If so, please send us the "boot.ini" file rather than the path. Thanks.
skumar00ae Posted September 16, 2013 Author Report Posted September 16, 2013 I can see the "boot.ini"file ,But I can`t sent the file . while attaching the file I getting a message like you are not have permission to attach.
WiseCleaner Posted September 23, 2013 Report Posted September 23, 2013 You can sent this files to us using email. Click Here.
