Posted
Thank you for your feedback.
It isn't a bug.
1, The old version 3.23, if you have selected the option "Encrypt files while hiding folder/file", when you drag a folder into wise folder hider, the folder will be encrypted and hidden at the same time.
2, The latest version 3.28, if you have selected the option "Encrypt files while hiding folder/file", when you drag a folder into wise folder hider, the folder only will be hidden, not encrypted. Unless you are using the button "Hide Folder" to hide the folder, it will be encrypted and hidden at the same time.
