roblrich Posted August 17, 2015 Report Posted August 17, 2015 When closing out Wise Care 365 Pro, I keep getting a '(18,8): Userld:.' error. I also get a '(28,8):Userld:.' error when I attempt to activate 'Clean up your computer regulary.' at the bottom of the Dash Board. Then it auto disables it after I close the program. I just downloaded and subscribed today and this is getting on my nerves. I have attempted to uninstall, reboot and reinstall but this hasn't helped.
WiseCleaner Posted August 18, 2015 Report Posted August 18, 2015 Thank you for your feedback. It is a rare error, we suspect your Windows account is not complete, causing wise care 365 cannot create a scheduled task. Currently we don't know how to fix it. You can try to create the task manually. 1, press Win+S, enter task scheduler 2, click Create Task on left window 3, General tab, enter Task name: Wise Care 365 PC Checkup Task Description: A regular automatic clean by Wise Care 365 helps keep your PC at peak performance and saves your time. Tick these 2 options: Run only when user is logged on and Run with highest privileges 4, Triggers tab, click New 5, Actions tab, click New, Action: Start a program Progran/script: C:\Program Files (x86)\Wise\Wise Care 365\WiseCare365.exe Add arguments: -c Start in: C:\Program Files (x86)\Wise\Wise Care 365 6, Conditions tab, un-tick all options 7, Settings tab, tick these 2 options: All task to be run on demand and Run task as soon as possible after a scheduled start is missed 8, clcik OK to save.
roblrich Posted August 20, 2015 Author Report Posted August 20, 2015 Had an update just now, and it fixed the error popups somehow.
wisecleaner_admin Posted August 25, 2015 Report Posted August 25, 2015 Yes, the latest v3.82 has improved it. If you have any question, please feel free to contact us!
