azooz Posted June 3, 2015 Report Posted June 3, 2015 eroor gamez (.*c000007b) Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 8057 MB CPU: Intel® Core i5-4440 CPU @ 3.10GHz Drive Info: C: 244.04 GB D: 292.97 GB E: 394.40 GB Internet Explorer: 8.0
xilolee Posted June 4, 2015 Report Posted June 4, 2015 I can't read the error in your screenshot, because it is in arabic. Could you write it here? Download and run System Update Readiness Tool for Windows 7 for x64-based Systems (KB947821) [October 2014] From an elevated command prompt, launch (Windows installation cd could be necessary): sfc /scannowWait till it finishes (15-50 minutes).If the final result is equal to Windows Resource Protection did not find any integrity violations or equal to Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command: copy %SYSTEMROOT%\Logs\CBS\CheckSUR.log "%userprofile%\desktop\CheckSUR.txt"After it, you should find checkSUR.txt on your desktop: post it here. Instead if the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch both the previous command in the code above AND also this command: copy %SYSTEMROOT%\logs\cbs\cbs.log "%userprofile%\desktop\cbs.txt" && findstr /c:"[SR]" "%userprofile%\desktop\cbs.txt" > "%userprofile%\desktop\SR.txt"After those two commands, you should find three files on your desktop: checkSUR.txt, cbs.txt and SR.txt: post here the checkSUR.txt and the sr.txt.If the last command won't work, try these (one by one): copy %SYSTEMROOT%\logs\cbs\cbs.log "%userprofile%\desktop\cbs.txt" findstr /c:"[SR]" "%userprofile%\desktop\cbs.txt" > "%userprofile%\desktop\SR.txt" How to run an elevated command prompt for Windows vista/seven users One of these three methods: - click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear
