Posted
po uruchomieniu komputera pojawia się taki komunikat jak na załaczonym zrzucie ekranu.
translated from polish
statement
when you start your computer this message appears as the attached screenshot.
Operating system:Windows 7 Professional (64 bit) Service Pack 1
System root: C:Windows
Available physical memory: 3582 MB
CPU: AMD Athlon II X2 250 Processor
C: 97,66 GB
D: 195,32 GB
E: 638,53 GB
Internet Explorer: 11.0
Posted
Hey bogdan,
I searched your problem on Internet, Microsoft Community has a solution, I'm not sure whether it can help you, you can try it.
The comment is here: http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/systemsysmenudll-the-specified-module-could-not-be/809f79e3-db5e-455b-aebb-4c0f66a8babc
The following is the solution:
1, Download Auto Runs.
http://download.sysinternals.com/files/Autoruns.zip
Link basis: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
2, Find the yellow highlighted Image Paths that ends with sysmenu.dll. Usually you can locate those image paths from Scheduled Task.
3, Right click then delete.
4, Try to find all yellow highlighted Image Paths that ends with sysmenu.dll from "Everything tabs, delete them.
NOTE: Carefully choose image paths that ends sysmenu.dll only, if you deleted paths that are not high lightened then it might cause some trouble booting your PC.
5, Reboot Computer
6, Wait at least 5 minutes to confirm that the issue has been resolved. (sysmenu.dll usually appears within a minute from rebooting the computer. )
