PMLEBLANC Posted May 18, 2015 Report Share Posted May 18, 2015 several times a day computer jsut reboots without warning Windows 8.1 64 bit Operating system:Windows 8.1 Pro with Media Center (64 bit) System root: C:WINDOWS Available physical memory: 4094 MB CPU: Intel® Core2 Duo CPU E8400 @ 3.00GHz Drive Info: C: 59.53 GB F: 235.17 GB G: 230.47 GB Internet Explorer: 11.0 Ekbergwef and RudyJainy 2 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 22, 2015 Report Share Posted May 22, 2015 1, Please open your antivirus software to do a deep scan 2, press Win+S, enter schedule tasks, open it, check out if there is suspect task to start a program that will reboot system 3, Have you installed similar auto-reboot software? 4, If you can, please check the power voltage whether is stable Link to comment Share on other sites More sharing options...
