Popular Post wisecleaner_admin Posted August 8, 2014 Popular Post Report Share Posted August 8, 2014 Dear users, We have just released a new product: Wise System Monitor Beta, a free and functional system monitoring tool. As we all know, Once system resources reach full capacities, or the hardware components get too hot, full functionality cannot be guaranteed. It is more than necessary to monitor the real time system and hardware condition of our PC. Wise System Monitor Beta offers you a simple way to achieve that. It enables you to monitor memory usage, CPU usage, all the processes running and main hardware component info of your PC. Since you know what is consuming your RAM and CPU, which part of your PC is overheated, you can deal with them accordingly to ensure your computer functionality. Click here for direct download: http://downloads.wisecleaner.com/soft/WSMSetup.exe However, there is still space for improvement for this beta version, please leave a comment or write down the bugs you found below. We would really appreciate that. Thank you! WiseCleaner Team Stevenchuck, Latorialavy, LillianJiX and 58 others 61 Link to comment Share on other sites More sharing options...
Nesivos Posted August 8, 2014 Report Share Posted August 8, 2014 When I click on the RAM usage number and CPU usage graph on the widget (Float Window) the individual programs using the most of each pop up with their usage. This is good. However, the usage numbers remain stagnate' i.e. unchanged which means real-time numbers are not showing for each program but only a snaphshot of what the numbers were when I clicked on the widget ISTM that the numbers for each program should change in real-time after you click on RAM and CPU. Also the graph is too small to be meaningful. I would show a number for CPU usage number in the widget rather than the graph. Widget can be moved to a second monitor and appears to work fine. However, I have not tested to see if the widget remains after a restart or cold boot in the same location on the monitor where I had moved it to before the restart or cold boot. W8.1 Updated Intel i5 with Intel graphics card on monitor 1920 x 1080 That is it for now. GalenPep 1 Link to comment Share on other sites More sharing options...
Injeun Posted September 5, 2014 Report Share Posted September 5, 2014 -Only one problem: Even though it is set to run at startup, it does not. i can also see that it is listed in another utility list of startup items to start automatically. At any rate, I must start it manually. -I agree with Nesivos that the cpu graph in the widget is too small and should be changed to a cpu usage number. -I am happy with all else for now. Thank you for the use of this cool tool. It's just what I was looking for and would make a nice addition to WiseCare365Pro. -I'm running Windows 7 Home with all updates Link to comment Share on other sites More sharing options...
Injeun Posted September 8, 2014 Report Share Posted September 8, 2014 Sometimes the monitor widget shows up on my desktop, other times not. If it does show and I try to move it left, right, up or down via dragging, it disappears entirely. I've not experienced any similarly odd behavior from any other software or program on my computer. RidgeViz 1 Link to comment Share on other sites More sharing options...
Jaspion Posted October 30, 2014 Report Share Posted October 30, 2014 The product looks promising! But the program does not show my upload/download speed. FortopR and RidgeViz 1 1 Link to comment Share on other sites More sharing options...
