Some settings are managed by your system administrator
Some settings are managed by your system administrator in Internet Properties(internet options)
Operating system:Windows 8.1 Pro (64 bit)
System root: C:\WINDOWS
Available physical memory: 6088 MB
CPU: Intel® Core i3-2350M CPU @ 2.30GHz
C: 199.90 GB
E: 264.68 GB
Internet Explorer: 11.0
Link to comment
Are you logged as an administrator (or an user with administrator privileges) when that happens?
Have you modified any option through Group policy editor (Gpedit)?
There is a setting in SpyBot search and destroy that could cause the appearing of that message... Hence, if you are using SpyBot program, that message could be normal.
Some viruses/malwares could cause that setting to appear, so please check
Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer.
Otherwise (if you aren't using SpyBot S&DE or similar programs) you could try to reset gpedit through an elevated command prompt, with these commands:
RD /S /Q c:\Windows\System32\GroupPolicy
RD /S /Q c:\Windows\System32\GroupPolicyUsers
Link to comment
What have you tried?
I don't think you have already used the programs to scan your computer.
i tried this >
ok, i scan my laptop now...but using Windows Defender...because my internet slow right now
maybe i will tried other software later
Link to comment
