acoustic words Posted March 28, 2014 Report Share Posted March 28, 2014 When I run the defragmenting program in Wise Disk Cleaner 8.06.576, it defrags my E drive with no problem, but it seems to be ignoring my C drive completely. (Yes, I have both C and E drives checked on the options!). It analyzes and optimizes E drive, and says it's "analyzing" C drive, but nothing is actually happening on C drive -- analysis remains at 0% indefinitely. I've tried running a defrag only (no optimization) on C drive; I've tried running the program (defrag alone and defrag and optimize) on C drive only (no E drive); I've even uninstalled Wise Disk Cleaner and reinstalled a fresh copy of it -- nothing has helped so far. I think this started with 8 Beta, and I've hoped that each update would solve the issue, but so far, they haven't. Any thoughts? nohnigefearxv76, kapedKab, fapedKab and 2 others 5 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 31, 2014 Report Share Posted March 31, 2014 Hi, Does your C drive is SSD disk? Wise Disk Cleaner will not defrag SSD disk. Link to comment Share on other sites More sharing options...
acoustic words Posted April 1, 2014 Author Report Share Posted April 1, 2014 Unfortunately, I'm not tech-savvy enough to know what an SSD drive is. How can I find out if my C drive is an SSD drive? I have been using Wise Cleaner for some time now, and had no problem with earlier versions. It was only after upgrading to 8 Beta that it would not recognize my C drive. This includes uninstalling 8 Beta and installing the official version 8 when it was released. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 1, 2014 Report Share Posted April 1, 2014 Hi, Do you means old version of Wise Disk Cleaner can recognize your C drive? Wise Disk Cleaner 7? Do you install Wise Care 365 / Wise Data Recovery / Wise Jet Search? All of them will read your disk info. This way can check out whether your C drive is SSD. Right click My Computer-->Manage-->Device Manager, expand Disk drives, it will display your disk info. Link to comment Share on other sites More sharing options...
