Davy49 Posted March 5, 2018 Report Share Posted March 5, 2018 Hi, I was using a different software ( Revo UnInstaller ) to uninstall the program's / software that I wanted to delete off my computer. While revo seemed to function pretty well, it didn't always seem to find all of the installed program's on my computer. The wise program uninstaller does seem to find all of the program's that are installed, but doesn't always offer me the 'forced uninstall' option, shouldn't I ALWAYS be offered BOTH option's when I want to uninstall software on my computer ? Thanks, David TobacWab, RobertPhesk, Sylviafiply and 6 others 9 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 6, 2018 Report Share Posted March 6, 2018 Hi, we recommend Force Uninstall only if you cannot uninstall an app in Safe Uninstall. There is a Force Uninstall button under every installed app (except Windows 10 build-in apps), you can click it to Force Uninstall the app as you like. Link to comment Share on other sites More sharing options...
Davy49 Posted March 6, 2018 Author Report Share Posted March 6, 2018 Hi, Thanks for your reply..yesterday I was using your uninstall software on my windows 10 laptop, I was trying to delete all of the different programs that were included when I installed Sophos Home Premium antivirus software. While viewing all of those different component's under the 'All Software' button, I was only offered the safe uninstall option, the forced uninstall option was grayed out..I thought that was rather strange. Thanks, David Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 7, 2018 Report Share Posted March 7, 2018 Hi, Please select Desktop Programs icon, then you will see Forced Uninstall is enabled. If you uninstall a program from here Desktop Programs, all components of this program will be removed either. Link to comment Share on other sites More sharing options...
