LAMBDA471
Advanced Cleaner's advanced settings on Windows 10
If all options here are selected, and then Advanced Cleaner scans and cleans everything, the next time I start my computer, Windows 10 doesn't boot properly, I don't remember if it actually boots to desktop or not, but after that Windows 10 becomes unusable and even Restart doesn't fix it. It has to be completely reinstalled.
I'm not sure if it just breaks the Modern parts like taskbar, start menu, notifications, volume control, etc. as they don't appear when you click them, but I also think it breaks Cortana, which is essential to the start menu's searching.
I haven't gone in detail to test out every single option and which one affects Windows 10 like this, because it would take me more than a whole day of breaking and reinstalling Windows 10 just to find out which is it.
I would like you to review this and fix it, because selecting all options can discover some extra 500 MB of files to delete, apparently not all of them are junk, since it breaks Windows 10.
Please find a way to fix this.
Hi LAMBDA471.
I'm sorry you've got that awful problem.
I suspect the culprit is the latest entry *.log?, because it finds many files in vital places.
The following list shows what it finds on my machine:
C:\Windows\appcompat\Programs\Amcache.hve.LOG1
C:\Windows\appcompat\Programs\Amcache.hve.LOG2
C:\Windows\System32\config\systemprofile\ntuser.dat.LOG1
C:\Windows\System32\config\systemprofile\ntuser.dat.LOG2
C:\Windows\System32\config\bbimigrate\BBI.LOG1
C:\Windows\System32\config\bbimigrate\BBI.LOG2
C:\Windows\System32\config\RegBack\SECURITY.LOG1
C:\Windows\System32\config\RegBack\SECURITY.LOG2
C:\Windows\System32\config\RegBack\SOFTWARE.LOG1
C:\Windows\System32\config\RegBack\SOFTWARE.LOG2
C:\Windows\System32\config\RegBack\SYSTEM.LOG1
C:\Windows\System32\config\RegBack\SYSTEM.LOG2
C:\Windows\System32\config\RegBack\DEFAULT.LOG1
C:\Windows\System32\config\RegBack\DEFAULT.LOG2
C:\Windows\System32\config\RegBack\SAM.LOG1
C:\Windows\System32\config\RegBack\SAM.LOG2
C:\Windows\System32\config\userdiff.LOG1
C:\Windows\System32\config\userdiff.LOG2
C:\Windows\System32\config\BBI.LOG1
C:\Windows\System32\config\ELAM.LOG1
C:\Windows\System32\config\COMPONENTS.LOG1
C:\Windows\System32\config\DEFAULT.LOG1
C:\Windows\System32\config\DRIVERS.LOG1
C:\Windows\System32\config\SAM.LOG1
C:\Windows\System32\config\SECURITY.LOG1
C:\Windows\System32\config\SYSTEM.LOG1
C:\Windows\System32\config\COMPONENTS.LOG2
C:\Windows\System32\config\DEFAULT.LOG2
C:\Windows\System32\config\DRIVERS.LOG2
C:\Windows\System32\config\SAM.LOG2
C:\Windows\System32\config\SECURITY.LOG2
C:\Windows\System32\config\SOFTWARE.LOG2
C:\Windows\System32\config\SYSTEM.LOG2
C:\Windows\System32\config\BBI.LOG2
C:\Windows\System32\config\BCD-Template.LOG1
C:\Windows\System32\config\BCD-Template.LOG2
C:\Windows\System32\config\ELAM.LOG2
C:\Windows\System32\config\SOFTWARE.LOG1
C:\Windows\System32\SMI\Store\Machine\SCHEMA.DAT.LOG1
C:\Windows\System32\SMI\Store\Machine\SCHEMA.DAT.LOG2
C:\Windows\System32\Microsoft\Protect\Recovery\Recovery.dat.LOG1
C:\Windows\System32\Microsoft\Protect\Recovery\Recovery.dat.LOG2
C:\Windows\SysWOW64\config\systemprofile\ntuser.dat.LOG1
C:\Windows\SysWOW64\config\systemprofile\ntuser.dat.LOG2
C:\Windows\SysWOW64\config\SOFTWARE.rhk.LOG1
C:\Windows\SysWOW64\config\SOFTWARE.rhk.LOG2
C:\Windows\SysWOW64\config\DEFAULT.rhk.LOG1
C:\Windows\SysWOW64\config\DEFAULT.rhk.LOG2
C:\Windows\SysWOW64\config\SECURITY.rhk.LOG1
C:\Windows\SysWOW64\config\SECURITY.rhk.LOG2
C:\Windows\SysWOW64\config\SAM.rhk.LOG1
C:\Windows\SysWOW64\config\SAM.rhk.LOG2
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
C:\Windows\ServiceProfiles\NetworkService\NTUSER.rhk.LOG1
C:\Windows\ServiceProfiles\NetworkService\NTUSER.rhk.LOG2
C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT.LOG1
C:\Windows\ServiceProfiles\NetworkService\NTUSER.DAT.LOG2
C:\Windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
C:\Windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
C:\Windows\ServiceProfiles\LocalService\NTUSER.rhk.LOG1
C:\Windows\ServiceProfiles\LocalService\NTUSER.rhk.LOG2
C:\Windows\ServiceProfiles\LocalService\NTUSER.DAT.LOG1
C:\Windows\ServiceProfiles\LocalService\NTUSER.DAT.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\microsoft.windowscommunicationsapps_17.6868.41141.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\microsoft.windowscommunicationsapps_17.6868.41141.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Windows.ContactSupport_cw5n1h2txyewy\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Windows.ContactSupport_cw5n1h2txyewy\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe\Microsoft.ZuneVideo_3.6.20961.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe\Microsoft.ZuneVideo_3.6.20961.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneMusic_8wekyb3d8bbwe\Microsoft.ZuneMusic_3.6.20961.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ZuneMusic_8wekyb3d8bbwe\Microsoft.ZuneMusic_3.6.20961.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.XboxApp_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.XboxApp_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.XboxApp_8wekyb3d8bbwe\Microsoft.XboxApp_15.17.3003.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.XboxApp_8wekyb3d8bbwe\Microsoft.XboxApp_15.17.3003.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsStore_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsStore_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsStore_8wekyb3d8bbwe\Microsoft.WindowsStore_11602.1.26.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsStore_8wekyb3d8bbwe\Microsoft.WindowsStore_11602.1.26.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsReadingList_8wekyb3d8bbwe\Microsoft.WindowsReadingList_6.3.9654.21199_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsReadingList_8wekyb3d8bbwe\Microsoft.WindowsReadingList_6.3.9654.21199_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsMaps_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsMaps_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsMaps_8wekyb3d8bbwe\Microsoft.WindowsMaps_4.1603.1190.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsMaps_8wekyb3d8bbwe\Microsoft.WindowsMaps_4.1603.1190.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsCamera_8wekyb3d8bbwe\Microsoft.WindowsCamera_2016.404.120.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsCamera_8wekyb3d8bbwe\Microsoft.WindowsCamera_2016.404.120.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsCalculator_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsCalculator_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsAlarms_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsAlarms_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsAlarms_8wekyb3d8bbwe\Microsoft.WindowsAlarms_10.1603.12020.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.WindowsAlarms_8wekyb3d8bbwe\Microsoft.WindowsAlarms_10.1603.12020.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.ShellExperienceHost_cw5n1h2txyewy\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.ShellExperienceHost_cw5n1h2txyewy\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Photos_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Photos_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Photos_8wekyb3d8bbwe\Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Photos_8wekyb3d8bbwe\Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\LocalState\speech_onecorereg.bin.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.Cortana_cw5n1h2txyewy\LocalState\speech_onecorereg.bin.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.People_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.People_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.People_8wekyb3d8bbwe\Microsoft.People_10.0.10811.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.People_8wekyb3d8bbwe\Microsoft.People_10.0.10811.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Office.Sway_8wekyb3d8bbwe\Microsoft.Office.Sway_17.6965.45231.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Office.Sway_8wekyb3d8bbwe\Microsoft.Office.Sway_17.6965.45231.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Office.OneNote_8wekyb3d8bbwe\Microsoft.Office.OneNote_17.6965.57881.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Office.OneNote_8wekyb3d8bbwe\Microsoft.Office.OneNote_17.6965.57881.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Runtime.1.3_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Runtime.1.3_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Framework.1.3_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Framework.1.3_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Framework.1.2_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.NET.Native.Framework.1.2_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftSolitaireCollection_8wekyb3d8bbwe\Microsoft.MicrosoftSolitaireCollection_3.9.5250.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftSolitaireCollection_8wekyb3d8bbwe\Microsoft.MicrosoftSolitaireCollection_3.9.5250.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftOfficeHub_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftOfficeHub_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftOfficeHub_8wekyb3d8bbwe\Microsoft.MicrosoftOfficeHub_17.7012.23531.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftOfficeHub_8wekyb3d8bbwe\Microsoft.MicrosoftOfficeHub_17.7012.23531.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Messaging_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Messaging_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Messaging_8wekyb3d8bbwe\Microsoft.Messaging_2.15.20002.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Messaging_8wekyb3d8bbwe\Microsoft.Messaging_2.15.20002.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Getstarted_8wekyb3d8bbwe\Microsoft.Getstarted_3.5.11.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Getstarted_8wekyb3d8bbwe\Microsoft.Getstarted_3.5.11.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ConnectivityStore_8wekyb3d8bbwe\Microsoft.ConnectivityStore_1.1604.4.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.ConnectivityStore_8wekyb3d8bbwe\Microsoft.ConnectivityStore_1.1604.4.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.CommsPhone_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.CommsPhone_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.CommsPhone_8wekyb3d8bbwe\Microsoft.CommsPhone_2.17.27003.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.CommsPhone_8wekyb3d8bbwe\Microsoft.CommsPhone_2.17.27003.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingWeather_8wekyb3d8bbwe\Microsoft.BingWeather_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingWeather_8wekyb3d8bbwe\Microsoft.BingWeather_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingSports_8wekyb3d8bbwe\Microsoft.BingSports_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingSports_8wekyb3d8bbwe\Microsoft.BingSports_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingNews_8wekyb3d8bbwe\Microsoft.BingNews_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingNews_8wekyb3d8bbwe\Microsoft.BingNews_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingFinance_8wekyb3d8bbwe\Microsoft.BingFinance_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.BingFinance_8wekyb3d8bbwe\Microsoft.BingFinance_4.9.76.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Microsoft.Advertising.Xaml_10.0.1605.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Microsoft.Advertising.Xaml_10.0.1605.0_x86__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Microsoft.Advertising.Xaml_10.0.1605.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.Advertising.Xaml_8wekyb3d8bbwe\Microsoft.Advertising.Xaml_10.0.1605.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.AAD.BrokerPlugin_cw5n1h2txyewy\Settings\settings.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.AAD.BrokerPlugin_cw5n1h2txyewy\Settings\settings.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.3DBuilder_8wekyb3d8bbwe\Microsoft.3DBuilder_11.1.8.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\Microsoft.3DBuilder_8wekyb3d8bbwe\Microsoft.3DBuilder_11.1.8.0_x64__8wekyb3d8bbwe\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Packages\AD2F1837.HPPrinterControl_v10z8vjag6ke6\AD2F1837.HPPrinterControl_58.1.78.0_x86__v10z8vjag6ke6\ActivationStore\ActivationStore.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Packages\AD2F1837.HPPrinterControl_v10z8vjag6ke6\AD2F1837.HPPrinterControl_58.1.78.0_x86__v10z8vjag6ke6\ActivationStore\ActivationStore.dat.LOG2
C:\Users\XILOLEE\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
C:\Users\XILOLEE\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
C:\Users\XILOLEE\ntuser.dat.LOG1
C:\Users\XILOLEE\ntuser.dat.LOG2
C:\Users\Public\ntuser.dat.LOG1
C:\Users\Public\ntuser.dat.LOG2
C:\Users\Default\NTUSER.DAT.LOG1
C:\Users\Default\NTUSER.DAT.LOG2
C:\Users\Default.migrated\ntuser.dat.LOG1
C:\Users\Default.migrated\ntuser.dat.LOG2
C:\Users\Administrator\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
C:\Users\Administrator\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
C:\Users\Administrator\ntuser.dat.LOG1
C:\Users\Administrator\ntuser.dat.LOG2
C:\ProgramData\ntuser.dat.LOG1
C:\ProgramData\ntuser.dat.LOG2
I honestly have unticked all items with LOG in them, and *.bak (because of emule part files), since many months/years.
I've also been very cautious with searching and deleting empty files (i.e., I did not delete them).
By the way, the advanced cleaner is named advanced because it should be used by advanced (and brave) users.
Someone of the staff (most likely WiseCleaner_Admin) will probably give you a better and more authoritative answer than mine, from Monday onwards.
Hope this helps.
