Omar_Jokr
[Solved - Win7] Help and support was not able to start
when i try to run help and support of windows, I got this error.
"this image is not from my pc because my langauage is arabic"
System root: C:\Windows
Available physical memory: 3033 MB
CPU: Intel® Pentium® Dual CPU T3400 @ 2.16GHz
C: 147.35 GB
D: 150.64 GB
Internet Explorer: 10.0
Please follow the fsteps below.
Right-click My Computer.
Pull down to Manage.
Expand [+] the Services and Applications branch.
Click on Services. Scroll down to Help and Support. Double click that.
In the Startup type pulldown, set it to Automatic.
Reboot your PC.
Thanks.
:( It is too bad.
Try following steps:
1, If you use wise care 365 to slim system (delete the Help files), and you never uninstall wise care 365, you can restore it.
   Run wise care 365-----Restore----System restore, select a point to restore.
2, If you don't have a restore point, use this way.
    Open C:\Windows, find the folder Help (if it not exist, create a new folder named "Help"), right-click it, click Restore previous versions, select a earlier point, Copy it to a specify location
post-45-0-13673500-1377254286_thumb.jpg  post-45-0-71843700-1377254288_thumb.jpg
Then copy the folder and paste it to C:\Windows
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
