jasem Posted August 17, 2013 Report Share Posted August 17, 2013 got a problem your program says faild to creat restore point Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3317 MB CPU: Intel® Core i5 CPU 670 @ 3.47GHz Drive Info: C: 97.56 GB D: 97.65 GB E: 270.44 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
april Posted August 20, 2013 Report Share Posted August 20, 2013 Please try to solve the issue according to the solution below, thanks. 1.Confirm that the “Task Scheduler” and “System Restore Service” are running: Click Start, click Run, and then type cmd /k net Start then press enter. Make sure that the Task Scheduler and System Restore Service are up and running. To start the “Task Scheduler” Service. Go to Start - Run and type Services.msc then press enter. Double click on “Task Scheduler”. Set ‘Startup type’ to Automatic then press Start and Wait for the Service Control progress indicator to close. Do the same if the “System Restore Service” was missing. Under the Status column look for any entries that read "Starting" rather than "Started". Close the Services window. 2. Test System Restore to confirm it is functioning correctly. Create a new restore point named TEST. Create a new folder on the desktop an name it TEST. Now restore to the Test restore point. You will receive a message if the restore was successful, and the Test folder on the desktop will be gone. The above test can also be performed in Safe Mode. Thanks. Link to comment Share on other sites More sharing options...
