Posted
Windows 7 Home Premium 64-bit SP 1
Dell Inspiron 19T Pentium Dual Core CPU
E5400 @ 2.70GHz 4.00 GB RAM
Unaable to System Restore Get Error code 0x81000203
I've looked online for solution, but have been unable to fix it
System root: C:\Windows
Available physical memory: 4061 MB
CPU: Pentium® Dual-Core CPU E5400 @ 2.70GHz
C: 451.07 GB
Internet Explorer: 10.0
Posted
Please try to solve the issue using the following the instruction. Thanks.
Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: chkdsk /r /f
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
Thanks.
Posted
Click Start, type services.msc in search bar, find out Microsoft Software Shadow Copy Provider, double click it, modify its startup type as Manual or Automatic, then close window and restart system.
