9reade 0 Posted October 8, 2014 Report Share Posted October 8, 2014 Slow start-up and intermittent stopping leads me to believe that multiple registry errors need to be repaired. Have you got any solutions on offer? Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 8, 2014 Report Share Posted October 8, 2014 Check the following topics: How to speed up your PC by WiseCleaner_Admin How to speed up a computer; speed up any PC or laptop (Part One) by Linkin How to speed up a computer; speed up any PC or laptop (Part Two) by Linkin Or try these operations: 1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. 2) Open an elevated command prompt and type: cleanmgr /sageset:65535 Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this: cleanmgr /sagerun:65535Press enter and wait until it finishes. 3) Download adwcleaner portable (click) and run it. 4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 6) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix. 7) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 8) Launch sfc /scannow from an elevated command prompt (and report the result here) 9) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. Link to post Share on other sites
9reade 0 Posted October 9, 2014 Author Report Share Posted October 9, 2014 Array Link to post Share on other sites
xilolee 511 Posted October 9, 2014 Report Share Posted October 9, 2014 ? Link to post Share on other sites
9reade 0 Posted October 10, 2014 Author Report Share Posted October 10, 2014 Thank you for your e-mail advice of a NEW reply from Xilolee delivered hereon Oct 9, 2014 - 23.04 hrs: this however is NOT a new msg/reply to my report of Oct 9, 2014 as it has the same wording & references as the one which was sent in response to my Oct 8, 2014 enquiry - namely - http://forum.wisecleaner.com/index.php?/topic/7853-registry-errors/?view=getnewpost. Does this mean - you ARE human after all? No worries - all is forgiven, just waiting for that NEW msg from Xilolee as & when. Have a nice day. Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 11, 2014 Report Share Posted October 11, 2014 Does this mean - you ARE human after all? Yup. Me, I'm human. I didn't understand your second message (array?????) and I didn't understand your third reply, too. Maybe I don't understand almost anything, but I know something for sure: if someone asks for help, it should be clear as much as possible. Link to post Share on other sites
9reade 0 Posted October 11, 2014 Author Report Share Posted October 11, 2014 Hi – Xilolee, Tks for last reply (Oct 11, 2014). I did not realize that I had not expressed myself clearly with my submission on Oct 8, 2014: and I am very sorry to have made life difficult for you - 1) I found a ‘string’ of items in the registry report (did you receive this?) which I felt were NOT needed such as WAJAM – CROSS RIDER – SMART BAR – SPEEDMAX PC – SIEN SA - SEARCH PROJECT etc. I tried to explain I am NOT experienced enough to differentiate between ‘what is in support of Microsoft and what is NOT, I requested your guidance on what to delete and what not. 2) The Registry-Log was sent in support of the above request in case there were MORE of the NOT NEEDED items – those which I did not recognize as causing trouble for me. Once I have your definitive answer I shall complete the actions (sections 8 & 9) as detailed in your initial feedback of Oct 8, 2014 and report back of the results. Thank you for your patience and look forward to your reply in due course. Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 11, 2014 Report Share Posted October 11, 2014 Hi 9reade. I can't see your log(s). If you sent it via email, only wise team (i.e.: employees and bosses! And I'm not one of them) can see that. I found a ‘string’ of items in the registry report (did you receive this?) which I felt were NOT needed such as WAJAM – CROSS RIDER – SMART BAR – SPEEDMAX PC – SIEN SA - SEARCH PROJECT etc. Are you seeing those objects in system tuneup/startup manager? (screenshots are welcome) Have you downloaded and run adwcleaner (and fixed things with it, if necessary)? Link to post Share on other sites
9reade 0 Posted October 12, 2014 Author Report Share Posted October 12, 2014 Hi - Xilolee, Sorry it took me a while to get back - I created images of the adwcleaner results i.e what was found to be in the registry of my PC - I am not sure whether all 18 images have been stored after having selected them via the 'Select Image' prompt. I may have said before - I am not an expert on computer programming and because of that I do not want to remove anything from the registry that may do more harm then good - so: I am asking for your guidance: some of the problem items are obviousi.e. WAJAM - Cross Rider - Iminent - Superfish and others but I do ask for your help to determine which. Ref. your msg of Oct 8, 2014 - para#4: this is how far Ihave got - the system restore (para 5 etc.) I will take care of when I have your reply. Thank you. Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 12, 2014 Report Share Posted October 12, 2014 ADWCleaner removes only BAD things. If I were you, I'll remove everything adwcleaner shows! (I did it, when I used it) Link to post Share on other sites
9reade 0 Posted October 13, 2014 Author Report Share Posted October 13, 2014 Hi – Xilolee, Thanks for your last msg – I completed as per original directions incl. para 8 (went like a flash – could not make out what it was except black). Defragged via Wise Care365 PRO as well as OS W7 defrag-facility. All seems well... except my Windows Live Mail 2012: this is giving me a problem with the addresses for ‘categories' (could be holding as many as 47 names/addresses) preceded by 2 – 3 addresses: 1) I create an e-mail with the addresses (individuals & categories) from my address-book, deposit them in either ‘TOP’, BCC or CC. 2) enter subject 3) write message – then perhaps save into DRAFTS, retrieve it... 4) make address or text changes and then SEND it. Attached hopefully explain what the problem is - Capture 00 shows the first 2 names (not categorised) and ALL the others ARE categorised. Capture 01 shows location of category (containing ALL the names & e-mails addresses of the others shown). Capture 02 details on msg as it should go out – text added. Capture 03 returned to DRAFTS – now text added. Capture 04 retrieved from DRAFTS – category details MISSING Capture 05 test-msg sent to e-mail account to ensure that I can still receive msgs There has never been a problem until today: the msg created with the category, when retrieving it from DRAFTS, does no longer bear the category – only the individual names previously entered are visible. Can you please advise a solution i.e. re-install W7LM or – could there be a DLL missing? Thank you Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 14, 2014 Report Share Posted October 14, 2014 I'm not sure about what problem you have got about Windows live mail. (and I can see only one capture/screenshot) Link to post Share on other sites
9reade 0 Posted October 18, 2014 Author Report Share Posted October 18, 2014 Hi – Xilolee, sorry not to respond sooner to your last msg of Oct14, 2014. I completed as per your advice on Oct 12. The result was no cure of my issues. I restored the system to prior that date – I then looked thru all the options on WiseCare 365 PRO - 3.2.5. I found one which I had avoided (probably erring on the side of caution) and NOT opened up because of its definition ‘Disc Eraser’ for it sounded like I would erase everything! The small header-print I found encouraged me to bite the bullet, open it up and activate it – I could always (I’d hoped} fall back to system restore. I completed both my C & D drives and been trying to find any negative responses from any computer action I needed to take for any computer work. So far – all is well and it’s working better then for a long long time. The W7LM issue (your msg of Oct 14) I had also is NO LONGER an issue. Bottom Line: you did very well in coaching me along and, as a ’very cautious silver surfer’, and this recent experience behind me it was a good investment which had been recommended by a friend. Thank you for your patience and I hope I won’t have to trouble you again too soon. 9reade. Operating system:Windows 7 Ultimate (64 bit) System root: C:Windows Available physical memory: 3071 MB CPU: Intel® Atom CPU 330 @ 1.60GHz Drive Info: C: 142.45 GB D: 142.54 GB Internet Explorer: 10.0 Link to post Share on other sites
xilolee 511 Posted October 22, 2014 Report Share Posted October 22, 2014 All's Well That Ends Well Link to post Share on other sites
