graphic
how can i make a game run fast and clear without any graphic card
Operating system:Windows 7 Ultimate (32 bit)
System root: C:Windows
Available physical memory: 1911 MB
CPU: Intel® Core i3 CPU 540 @ 3.07GHz
C: 208.01 GB
D: 38.98 GB
E: 68.69 GB
I: 150.00 GB
Internet Explorer: 8.0
Link to comment
Hello sid,
According to your specs, you are using the integrated Intel 2500 graphics arrangement which only supports a limited amount of low-end games. So, if you are trying to play a game like Battlefield 4, I doubt there is anything that can be done to improve your experience. See here for a list of games that Intel claims should run OK:
http://www.intel.com/support/graphics/sb/CS-033387.htm
IMHO, upgrading may be your best solution. Note that the above list is for a 64 bit system; however, I can only assume that it might apply to a 32 bit system as well.
UCanFixit
Link to comment
