anisincool 0 Posted August 22, 2014 Report Share Posted August 22, 2014 Whenever i do start the VLC player after PC restart or start after shutdown, It take too much time(around 2-3 minute) to launch. What is root cause? Operating system:Windows 8 Pro (64 bit) System root: C:\Windows Available physical memory: 3876 MB CPU: Intel® Core i3-2310M CPU @ 2.10GHz Drive Info: C: 97.31 GB D: 122.07 GB E: 122.07 GB F: 123.96 GB Internet Explorer: 10.0 Link to post Share on other sites
rachelle 2 Posted August 22, 2014 Report Share Posted August 22, 2014 Yesterday I ve started using the new version of VLC player which is 1.1.4. Now everytime it changes a one video to another, screen goes black and then comes back. Anyone else experienced this problem ? or this is something to do with my PC. Link to post Share on other sites
tipstir 14 Posted August 22, 2014 Report Share Posted August 22, 2014 Flag in the system tray has a red mark, you should take care of that. LAN is off line too. Other than that. What does Wise Care say for Start-up apps your loading. Look under Startup Manager. Your system system is 4GB. Try using MicroSDHC Class 4 or 10 with 16GB. Then activate Ready Boost to help your system performance. If you can add additional 4GB to bring that i3 up to 8GB would be a lot better. How large is C: originally? Those other drive letters did you partition your C: into other drives letters? Download Super Anti-Spyware and run a Complete Scan on your system Link to post Share on other sites
xilolee 511 Posted September 2, 2014 Report Share Posted September 2, 2014 Try Reset preferences from VLC , and keep us informed! Link to post Share on other sites
