clifric Posted August 21, 2014 Report Posted August 21, 2014 When I boot up I get a message 'The instruction at "Ox7c919af2" reference memory at "oxoooooo1o" cannot be written' Press CANCEL to debug. I press Cancel and continue as usual - this happens every time I boot. When I load a streaming TV program I get a similar message and have to press CANCEL and try to reload several times before success. I get thi on both my desktop and my laptop so reckon Wisecare 365 has deleted something! Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\windows Available physical memory: 2047 MB CPU: Intel® Core2 Duo CPU E4500 @ 2.20GHz Drive Info: C: 146.48 GB D: 151.60 GB Internet Explorer: 8.0
tipstir Posted August 21, 2014 Report Posted August 21, 2014 What are you streaming from? Netflix. I know there is Media Center Bug with Netflix. I have the fix and reported to Wise to add to the Wise Care. But are you using VLC or something else?
UCanFixIt Posted August 21, 2014 Report Posted August 21, 2014 Sounds like a driver issue to me... did you update any drivers recently? If so, you could try reverting to the previous driver(s) or try this instead: Click Start, Run and in the box enter: services.msc Click OK to launch (run it) Locate the Windows Driver Foundation - User-mode Driver Framework service Right click the service, select Properties and choose Disabled Reboot and test with the above disabled
clifric Posted August 22, 2014 Author Report Posted August 22, 2014 Sounds like a driver issue to me... did you update any drivers recently? If so, you could try reverting to the previous driver(s) or try this instead: Click Start, Run and in the box enter: services.msc Click OK to launch (run it) Locate the Windows Driver Foundation - User-mode Driver Framework service Right click the service, select Properties and choose Disabled Reboot and test with the above disabled That has worked thank you very much - you were right - I did try and update my graphics driver and failed
UCanFixIt Posted August 23, 2014 Report Posted August 23, 2014 Hi clifric, Glad you got it working! UCabFixit
