van.Nieulande Posted August 19, 2014 Report Posted August 19, 2014 Herstelpunt maken gaat niet.Foutcode 0x81000203.Een onverwachte fout op de eigenschappen pagina ??Ik kan hiet niks meeKunt U helpen translated from dutchrestore pointRestore point is not.Error code 0x81000203.An unexpected error in the property page?I can palce anything with it?Can you help Operating system:Windows 7 Ultimate (64 bit) Service Pack 1System root: C:\WindowsAvailable physical memory: 8170 MBCPU: AMD FX-4170 Quad-Core ProcessorDrive Info:C: 465,76 GBD: 0,10 GBF: 713,67 GBG: 683,50 GBInternet Explorer: 11.0
xilolee Posted August 19, 2014 Report Posted August 19, 2014 1) Delete CBS.log inside C:\Windows\Logs\CBS 2) Note: windows installation/repair cd could be necessary. Launch sfc /scannow from an elevated command prompt, wait until it finishes (15-50 minutes), check the final result (note it down). If it says no integrity violations (or something similar), stop here... Otherwise restart your machine and relaunch the tool. Then, report both final results here. 3) If both results says that there are damaged files and it can not restore them, post here the CBS.log file (upload it using the forum feature or a website where you could upload files).
van.Nieulande Posted August 24, 2014 Author Report Posted August 24, 2014 Kan niet uploaden , Het probleem is er nog . Can not upload, the problem is still there.
xilolee Posted August 26, 2014 Report Posted August 26, 2014 You could use speedyshare.com to upload files.
van.Nieulande Posted September 16, 2014 Author Report Posted September 16, 2014 Tot op heden nog niet opgelost. ???
WiseCleaner Posted September 19, 2014 Report Posted September 19, 2014 Did you upload the CBS.log file to speedyshare.com? If not, you can try following method to fix this issue: Method 1: Did you install TuneUp Utilities and enable Turbo Mode? Turbo Mode block system protection / restore. Disable/turn off Turbo Mode may fix your issue. Method 2: Check if Microsoft Software Shadow Copy Provider service is disabled. This behavior is by design. Disabling System Restore will limits the ongoing usefulness of System Restore on the computer. To re-enable, please try: 1). Open gpedit.msc from Start Search box. 2). Navigate to the following branch. Computer Configuration\Administrative Template\System\System Restore. 3). In the right pane, please configure the “Turn off system restore” policy. Please set it to Not Configured.
