MrGKanev Posted June 13, 2013 Report Posted June 13, 2013 Hi I uninstalled the program but the problem is that i forget to unlock the folders and now i cant find it please help.I tried to use your recovery tool but didnt work.Please help only copy... EdwinBaw 1
StefZZZ Posted June 14, 2013 Report Posted June 14, 2013 Install it again > select Unhide > then the files are not hiden anymore. of course you must know the password.
Config Posted June 14, 2013 Report Posted June 14, 2013 Install it again > select Unhide > then the files are not hiden anymore. of course you must know the password. This is the answer!
MrGKanev Posted June 16, 2013 Author Report Posted June 16, 2013 Thanks that work i didnt think about it you can lock the topic.
