Jessbelow Posted April 17, 2014 Report Share Posted April 17, 2014 some updates were not installed. Failed: 1 update Error(s) found Code 80070002 Window update ran into a problem. get help with this error. Operating system:Windows 8 (64 bit) System root: C:\Windows Available physical memory: 4087 MB CPU: Intel® Core2 Duo CPU T5750 @ 2.00GHz Drive Info: C: 286.44 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 21, 2014 Report Share Posted April 21, 2014 This Windows Update error 80070002, you need to remove the temporary update files that Windows uses to identify updates for your computer. To remove the temporary files, stop the Windows Update service, delete the temporary update files, restart the Windows Update service, and then try to check for Windows updates again. Step 1, To stop the Windows Update service You must be logged on as an administrator to perform these steps. 1) Open Control Panel. In the search box, type administrative tools, and then click Administrative Tools. 2) Double-click Services. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation. 3) Click the Name column heading to sort the names in reverse order. 4) Find the Windows Update service, right-click it, and then click Stop. Step 2, To delete temporary update files 1) Open C:\Windows\SoftwareDistribution\DataStore, delete all files and folders in the folder. 2) Open C:\Windows\SoftwareDistribution\Download, delete all files in the folder. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation. Step 3, To restart the Windows Update service and check for Windows updates again Link to comment Share on other sites More sharing options...
