mando Posted February 11, 2014 Report Share Posted February 11, 2014 DeleT Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 11, 2014 Report Share Posted February 11, 2014 I wish you would have included your OS so I could have given you a more specific direction; however, this solution will work on all of them! So, it looks like you tried to remove the Conduit Search and it left a piece behind. With that said, download Autoruns, unzip it, run the portable executable as an admin, and delete the startup entry for the above: Note: You should see that entry in one of the run sections. Just uncheck the entry and delete it! Autoruns for Windows v11.70 Good luck. Link to comment Share on other sites More sharing options...
