Arcenter Posted February 6, 2014 Report Posted February 6, 2014 System retore is not working, so can't use or install several programs. Programs try to make a "restore point" as part of installation and it never completes the restore. Operating system:Windows 8 (64 bit) System root: C:\Windows Available physical memory: 22478 MB CPU: Intel® Core i7-4770 CPU @ 3.40GHz Drive Info: C: 2755.11 GB E: 0.11 GB F: 3725.89 GB G: 3725.89 GB L: 2794.51 GB M: 3726.01 GB Y: 0.48 GB Internet Explorer: 10.0
UCanFixIt Posted February 6, 2014 Report Posted February 6, 2014 See this tutorial on enabling/disabling automatic system restore point creation in Windows 8: http://www.eightforums.com/tutorials/33910-restore-point-automatic-creation-disable-windows.html You also want to make sure it is turned on and has adequate free space for your installations to auto-create new restore points as needed (FYI, mine is turned off): See attached image Good luck, UCanFixit
