ankita Posted February 5, 2014 Report Share Posted February 5, 2014 all application are opened with any of the open with application such as wordpad.then avg is also opened with wordpad. Operating system:Windows 7 Professional (32 bit) System root: C:\Windows Available physical memory: 2012 MB CPU: Pentium® Dual-Core CPU E5700 @ 3.00GHz Drive Info: C: 39.06 GB D: 48.83 GB E: 97.65 GB F: 112.54 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 5, 2014 Report Share Posted February 5, 2014 You appear to be infected by malware. With that said, I'm hoping only the shortcuts are affected. So, can you try and access AVG from the system tray? If not, can you access and run either AVG or Malwarebytes from the actual program directories where they reside (by clicking the actual executable)? If not, you can try downloading and running the Microsoft Safety Scanner from here and see if you can execute that directly: http://www.microsoft.com/security/scanner/en-us/default.aspx Link to comment Share on other sites More sharing options...
