Posted
Apart from the visible modifications adapted, Windows 8.1 raised its existing features to an extent. One of these latest enhancements is the optimized Power management feature.  The settings of this feature are molded in such a way that the external devices attached to the PC become irresponsive, if not active for a specified time and it does have a certain reason behind this activity.
Each of the modern time’s computing devices is specially designed to optimize its energy consumption. Microsoft has ensured to comply with this contemporary requisite in its latest version of operating system, Windows 8.1.
External devices that connect to a PC via USB controllers tend to intake a degree of electric charge. This keeps the device alive and active to correspond with the system. However, in Windows 8.1, when the device is not used or communicated within a specified timeframe, it enters a low power state. As a result, the device/drive does not show up in the connected devices, unexpectedly suspending the thread of a window browsing the USB device.
Many users have reported this issue as a system error and are in search of a perpetual solution. Let us show you how to get rid of this irritatingSuspend on Idle feature. Although the actual fix is to be carried within Windows Registry, you would have to identify the hardware ID of your subject device, connected through USB.
Locate Hardware ID
Plug in your device by inserting it into the USB slot
Right click on Windows 8.1 Start button to bring up the Power User menu
Locate and click Device Manager in the recorded settings
In the listed categories of hardware, click to expand Disk drives
(Note: Considering the instance of a USB storage device, we are tracing it under disk drives)
Select your USB storage device
While it is selected, go to View menu and list Devices by connection
You will directed to a detailed list where you can see the device underUSB Mass
Storage Device node
Right-click USB Mass Storage Device node and access it’s Properties
In the Properties window, go to Details tab and choose Hardware Idsin Property field
In the Value box, note down 4 digit values stated after VID and PID, respectively
Resolve in Registry
Press Windows key + Run on your keyboard to open Run box
Type regedit in the Run box and hit Enter
Click Yes to confirm the UAC message and open up Registry Editor
In the left pane of Registry Editor, expand HKEY_LOCAL_MACHINE to navigate
following key
SYSTEM\CurrentControlSet\Control\usbstor
Right click usbstor and choose New to create a Key under it
Name this newly created key as the 8 digit value of VID and PID, noted earlier
Right click this new key to create a New DWORD Value
Name the value as DeviceHackFlags and double click it to Modify
Choose Hexadecimal as the Base and put 400 in the field next toValue data
Click OK to save your changes and Exit Registry Editor
Once you are done with the above procedures, disconnect your USB controller device and reconnect it after a while. From now on, you will not experience a suspended external device connected through USB, even if it is left idle for hours.
