rene523 Posted November 11, 2013 Report Share Posted November 11, 2013 電腦常常用到一半自動關機 看影片也自動關機 不知到哪裡出問題 Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 12279 MB CPU: Intel® Core i7 CPU 860 @ 2.80GHz Drive Info: C: 48.83 GB D: 439.45 GB E: 443.22 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
Lucy Posted November 11, 2013 Report Share Posted November 11, 2013 1. First check it is the hardware problem or not, focusing on checking if it is problem of the motherboard, CPU fan, the host power supply situation, the power outlet or not. 2. Check it is some application software tasks complete shutdown to be enabled or not. This can clearly. Feature is that before turned off computer, it will always have a program has finished running, a dialog box will pop general reminder to be turned off. 3. try to use Wise Cleaner 365 to repair damaged file system and it can be a complete virus removal and repair of the system configuration. Link to comment Share on other sites More sharing options...
