yasser Posted November 3, 2013 Report Posted November 3, 2013 الجهاز لا يريد تثبيت اي برنامج Operating system:Windows 7 Professional (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 2038 MB CPU: Intel® Pentium® D CPU 3.00GHz Drive Info: C: 29,29 GB D: 35,15 GB E: 45,23 GB F: 39,37 GB Internet Explorer: 10.0
Config Posted November 4, 2013 Report Posted November 4, 2013 Arabic to English: Device does not want to install any program
Linkin Posted November 4, 2013 Report Posted November 4, 2013 This could be caused by a Virus. Either way, you can fix this by editing the registry. Some things to keep in mind. If it is a virus, you don't want to reboot because the virus could cause more damage. But, if you are going to edit the registry you need to reboot in order to apply the settings. This makes things interesting. You will need to apply the registry fix first, then try to scan your computer for Viruses and hope it removes the virus before you reboot. Click Start Type regedt32 in the search box and click OK The Registry Editor will open, browse to the Registry Location below: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer In the Installer Folder of the Registry. We need to create a new Key. Right Click in the Installer folder window and choose New, Dword, and name it DisableMSI. Then open the new Registry key and set the Value to 0 -which is a zero Now you Done fixing the error, but you still need to Scan for Viruses before Rebooting.
