anil1967 Posted November 1, 2013 Report Posted November 1, 2013 Dear Sir, There is a problem with internet connection and proxy server is not responding and the web page is not connected. will u plz help me? Operating system:Windows 8 Pro (64 bit) System root: C:\Windows Available physical memory: 4028 MB CPU: Intel® Pentium® CPU B950 @ 2.10GHz Drive Info: C: 78.03 GB D: 107.42 GB E: 112.54 GB Internet Explorer: 10.0
Lucy Posted November 1, 2013 Report Posted November 1, 2013 1. Check the network physical connection is normal or not. 2. Win + R keyboard, enter CMD.exe, run the ipconfig, then check the IP address is normal or not; if the IP is normal, run the ping google.com (can be any URL), if can get the return value, the network is connected. 3. run the Wise PC 1stAid, the NO, six issue "cannot open webpages when surfing internet " i hope it will help you , thanks
