adfasdfa Posted October 30, 2013 Report Posted October 30, 2013 在网站上下载的快播软件,找不到文件无法卸载,在注册表里把有关快播的文件夹全部都删完了,但在桌面的“开始”里面还有快播软件。我也曾安装过正版的快播,但电脑上会同时存在两个快播软件,而不是将另一个软件挤掉。 Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:\windows Available physical memory: 1878 MB CPU: Intel® Core i3-2348M CPU @ 2.30GHz Drive Info: C: 60.00 GB D: 200.00 GB E: 100.00 GB F: 105.76 GB Internet Explorer: 10.0
Adam Posted October 30, 2013 Report Posted October 30, 2013 You can try to use the link as below to download Wise Care 365 to uninstall the files as you want http://www.wisecleaner.com/soft/WPU.zip
wisecleaner_admin Posted October 30, 2013 Report Posted October 30, 2013 1, Re-install the software (make sure you install it in the old ones directory) 2, Run Wise Program Uninstaller to uninstall it 3, Run Wise Care 365 to clean again.
