Posted
我電腦是筆記型。最近在使用時,三不五時弄到一半網路就會無法連結,重開後就又可以,但維持不了多長,則其時間不一定,限制存取時都有去"裝置管理員"檢查過網路介面卡等的狀況,也都沒有驚嘆號,但就是會有這種情況一直發生,在限制存取的同時,我有嘗試用手機連取wifi(因為是用分享器),結果卻是可以連而筆電無法連線,可以教我該如何解決這種問題嗎?
System root: C:\Windows
Available physical memory: 3948 MB
CPU: Intel® Core i3-2310M CPU @ 2.10GHz
C: 290.45 GB
D: 290.62 GB
Internet Explorer: 10.0
Posted
Need more information, unable to connect the network connection icon on whether to have an exclamation point, if you have, that is a hardware problem, or network card, or route, or there is something wrong with network card driver. If not, then is port congestion, what is the background program to see if was turned on in a large number of send data or receive data.
Posted
Update the driver, there is another message with a yellow exclamation point, what is the reason the network fails.
If it is not routing problem that NIC.
try to Update Drivers
Posted
Firstly When yellow excalmation appears  that often demonstrate thare is no network driver  .The general solution is that you can download software namely"Qu Dong Jing Ling' through searching engine 'Bai Du'   then use it to update matched driver for your networkwork card  you can try this way first
Secondly  you can visit or downdload the related driver on the offical website of your owned computer  though you can  dail the offical hotline to consult where you can download .
