PC RESTARTS WITHOUT NOTICE
my pc restarts or shutdown without notice what would be the solution on that?
Operating system:Microsoft Windows XP (32 bit) Service Pack 2
System root: C:\WINDOWS
Available physical memory: 1023 MB
CPU: Intel® Pentium® 4 CPU 2.80GHz
C: 38.96 GB
D: 35.59 GB
Internet Explorer: 6.0
Link to comment
Try this:  Press (Windows Key)+R and type in regedit and hit enter.  Locate the following key:
Location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Double Click on "PowerdownAfterShutdown"
Then,
Change it to "0" if it is "1" OR
Change it to "1" if it is "0".
And hit Enter.
Then restart the computer and after it restarts try to shutdown again.  Hopefully this will work for you. :)
If this doesn't work make sure you change the value in regedit back to what it was originally
Thanks.
Link to comment
 Share
