rhlockey Posted October 7, 2013 Report Share Posted October 7, 2013 Even though Power under Control Panel setting is for display to never dim while under AC power plugged in, the screen will keep going black after a few minutes of use, then when hitting a key will go back on, but it is a royal pain. Cannot find out why this is happening. It is a Toshiba Satellite with MC Windows 7 Ultimate, 64-bit OS. Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 6051 MB CPU: Intel® Core i7-2630QM CPU @ 2.00GHz Drive Info: C: 931.20 GB E: 0.31 GB Internet Explorer: 11.0 kathrynta16 1 Link to comment Share on other sites More sharing options...
WiseCleaner Posted October 8, 2013 Report Share Posted October 8, 2013 If it is desktop, then change the displayer to see whether its because of displayer problem; Exclude displayer being too hot, clean the dust on displayer, add engine oil, check again; If it isn't displayer's problem, then update the graphics card. Link to comment Share on other sites More sharing options...
