manacd Posted October 4, 2013 Report Posted October 4, 2013 Hyperlinks won't open. Operating system:Windows 8 (64 bit) System root: C:\windows Available physical memory: 6028 MB CPU: Intel® Core i3-3120M CPU @ 2.50GHz Drive Info: C: 584.89 GB Internet Explorer: 10.0
terry Posted October 4, 2013 Report Posted October 4, 2013 Hi, I think Wise PC Aid may help you to fix the problem, did you try it? If not, please try Wise PC 1stAid first, if the program can't help you to fix the issue, please let me know. Thanks,
manacd Posted November 17, 2013 Author Report Posted November 17, 2013 when I click on a page to open it, it says, "This page can't be displayed." Operating system:Windows 8 (64 bit) System root: C:\windows Available physical memory: 6028 MB CPU: Intel® Core i3-3120M CPU @ 2.50GHz Drive Info: C: 584.89 GB Internet Explorer: 10.0
xilolee Posted November 17, 2013 Report Posted November 17, 2013 Hi manacd! Every page, or only one? If only one: it could be down for some time (server administration?) Are you using a HOSTS file? Have you installed some new security suite (antivirus, firewall, adblock, and so forth)?
manacd Posted November 22, 2013 Author Report Posted November 22, 2013 hyperlink would not open. Operating system:Windows 8 (64 bit) System root: C:\windows Available physical memory: 6028 MB CPU: Intel® Core i3-3120M CPU @ 2.50GHz Drive Info: C: 584.89 GB Internet Explorer: 10.0
