cassidyjt Posted October 1, 2013 Report Share Posted October 1, 2013 Registry Editor message indicates Administrator disabled this feature. If so, this was done inadvertently - - my DVD/CD is no longer recognized as a device by the SYSTEM. Have attempted to trouble shoot the latter through the Control Panel - Device Mgr - but without success. Believe Glery Utilities and or CCleaner may have been the Utilities that were instrumental in my problems' creation. Glery automatically defragments H/D at startup. Glery also takes snapshot before and after it searches for malware and thus will not allow MSWindows XP to re-establish a working Configuration Point that was not created with GLERY UTILITIES. Can you help? jt Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1407 MB CPU: Mobile Intel® Pentium® 4 CPU 3.06GHz Drive Info: C: 55.89 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
Config Posted October 2, 2013 Report Share Posted October 2, 2013 First, please use Wise Program Uninstaller linked below to unintall the two tools you mentioned in your article above. http://www.wisecleaner.com/wiseuninstallerfree.html Then, please download and reinstall Wise Care 365 from the link below. http://www.wisecleaner.com/wisecare365.html Once Wise Care 365 is installed in your PC, plz give an overall body check and cleaning to your PC with this useful and comprehensive software. Finally, use Wise PC 1stAid to solve common problems of your PC. Thanks. Link to comment Share on other sites More sharing options...
