Posted
It's always like thiw even when it's connected (like now)
System root: C:\Windows
Available physical memory: 3236 MB
CPU: Intel® Core i5-2410M CPU @ 2.30GHz
C: 465,66 GB
Internet Explorer: 10.0
Posted
right-click network icon----Open network and sharing center-----Change adapter settings-----right-click your wireless adapter----Prperties------double-click TCP/IPv4-----checked Use the following IP address, fill in your IP address, press OK to save settings.
If you own the router, the IP address on its bouttom. regularly, it is 192.168.1.1
so, you can fill in:   Ip address                   192.168.1.123
                              Subnet mask                255.255.255.0
                              Default gateway           192.168.1.1
                              Preferred DNS server   8.8.8.8         (if you don't it, you can use the google DNS server)
Posted
"my connection now its via ethernet cable not wifi." so, the wi-fi icon show "no connection"
You can turn off your PC's WI-Fi connection.
Right-click network icon----Open network and sharing center-----Change adapter settings-----right-click your wireless adapter---click Disable.
