Radhwen Posted November 4, 2024 Report Posted November 4, 2024 Hello , I have a problem with silent uninstalling Wise Disk Cleaner. command used : (Start-Process "C:\Program Files (x86)\Wise\Wise Disk Cleaner\unins000.exe" -Argumentlist "/SILENT" -Wait -PassThru -NoNewWindow) please help me to solve.
wisecleaner_admin Posted November 7, 2024 Report Posted November 7, 2024 Dear user, Sorry about that. You can try this to uninstall Wise Disk Cleaner: 1. Press Win + I to open Settings 2. Click the Apps in the left, then click Installed apps in the right pane 3. Search Wise Disk Cleaner in the Search box, click the three dots, then tap on the Uninstall option to remove Wise Disk Cleaner.
