Lily Posted October 8, 2024 Report Posted October 8, 2024 This pc security software allows you to detect and remove any types of malicious software: rootkits, Trojans, Backdoors, Viruses, Worm, Spyware, Adware, Google Search Redirects, Unwanted Programs, etc. UnHackMe was initially created as anti-rootkit software, but currently, it eliminates all types of malicious software: rootkits, Trojans, worms, viruses and so on. How does UnHackMe work? Precise double-checking for a Windows-based PC, which allows identifying and eliminating any types of malicious software. One part of UnHackMe works in the normal Windows mode. The second part, called Warrior, offers an offline checking mode. They are not separated and work together using common databases, program modules, and settings. UnHackMe uses its own database to detect which programs you should remove from your PC. You can agree with it or not. If you find a program on the list that is OK, you can mark it as a False Positive. An important advantage of this malware removal tool is that you can find previously undetected malware by inspecting the results. Features Key Features of UnHackMe: Scanning of installed programs for “Potentially Unwanted Programs” (PUPs). Checking for junk files, created by PUPs, adware, and spyware. Scanning of Windows startup programs, services, and drivers. Testing Windows shortcuts. Scanning for rootkits. Examining the browsers’ search settings. Scanning the browser’s add-ons. Testing the hosts’ file and DNS settings. Testing startup files using several antivirus programs on the Virustotal.com. Click here and get it for free! TERMS: Program version: 16.50 Licensing Period: Lifetime No Free upgrade No free technical support Personal use only
