johnsonroger271 Posted September 17, 2013 Report Share Posted September 17, 2013 computer will not install updates from microsoft also on using wise cleaner or avast antivirus does not check all files Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 190 MB CPU: Intel® Celeron® M processor 1.40GHz Drive Info: C: 33.50 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
april Posted September 18, 2013 Report Share Posted September 18, 2013 1. Get the windows updater here and save to desktop:»download.windowsupdate.com/Windo···eAgent302. Start, Run, CMDType these two commands in (one at a time) into the black window to install the update agent. The service will be started again after installation automatically:net stop wuauserv"%userprofile%\Desktop\WindowsUpdateAgent30-x86.exe" /wuforce3. Finished. Try installing updates from the yellow shield OR update.microsoft.com. Should be good to go now. Thanks. Link to comment Share on other sites More sharing options...
