stormgnagarn Posted September 12, 2013 Report Share Posted September 12, 2013 bilden blir svart och det står ingen signal på skärmen när jag sätter in en kontakt, usb eller nätverks sladd, hörlurar i baksidan av min stationära PC. Ibland vid uppstart så, istället för att pipa, börjar hårddisken att "brumma" 3-4 ggr med nån sekunds mellanrum så omstart krävs. vanligtvis så hörs ett pip efterföljt av att disken börjar snurra. Det här är troligtvis 2 olika problem (sliten PC kanske?). Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4094 MB CPU: Intel® Core2 Duo CPU E7200 @ 2.53GHz Drive Info: C: 68,26 GB D: 527,81 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
april Posted September 13, 2013 Report Share Posted September 13, 2013 Sorry to tell you that we can not get your meaning completely, would you please post your issue in English? Do not forget to post a screenshot, it is very important for us to deal with this issue. Thank Thank you for your cooperation. Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 13, 2013 Report Share Posted September 13, 2013 Maybe you are right. you computer was broken. Please seek help from Professional and technical personnel. Link to comment Share on other sites More sharing options...
