michaelvi Posted July 10, 2013 Report Share Posted July 10, 2013 Hello, when erasing a disc in Privacy Protection, WiseCleaner searched for half an hour at position 1 sec. Then I gave up and stopped the process. Will it come to an end, even at that position? Regards, Michael Link to comment Share on other sites More sharing options...
april Posted July 11, 2013 Report Share Posted July 11, 2013 Yes,it will come to an end at that position if you press the 'stop' button. This situation is normal, because Disk Eraser will remove files that have been deleted and also will override them in case some data recovery will recover these deleted files. So it will takes a little longer time. The time consumption also has something to do with the spaces you want to erase and also the security level at the bottom you have chosen. So make sure you have spare time to erase your disks. Any other questions,feel free to tell us. Link to comment Share on other sites More sharing options...
