مشكلة الشاشة السوداء
اعاني من مشكلة الشاشة السوداء عند بدء تشغيل الكمبيوتر
System root: C:\Windows
Available physical memory: 2039 MB
CPU: Intel® Pentium® M processor 1.73GHz
C: 78,03 GB
E: 70,92 GB
Internet Explorer: 8.0
Link to comment
Please try the method below.
1) When you switch ON your computer, start tapping the "F8" key to get
"Windows Advanced Options"( if boot menu appears, press "Esc" key and keep
tapping the F8 key)
2) Select "Safe Mode with Networking"
3) Click on Start --> Run --> Type regedt32 and press Enter.
[ If you are using Windows Vista or 7 then click on Start --> In search box, type
regedt32 and press Enter.]
Registry Editor will be opened. Navigate to the following location
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
At the right side, find the strings shell & userinit and check the following
shell value data should be
Explorer.exe
userinit value data should be
C:\WINDOWS\system32\userinit.exe,
If shell and userinit are having different data values then change it as mentioned
above.
Just double click shell and userinit and enter the data values as
shell --> "Value data" should be
Explorer.exe
userinit --> "Value data" should be
Note: there is "," at the end of userinit.exe
Then download "Malwarebytes' Anti-Malware" from the below link.
http://en.kioskea.net/download/download-105-malwarebytes-anti-malware
Update it and perform "Full Scan"
Note : Default selected option is "Quick Scan"
Thanks.
Link to comment
