[Solved - Win7] BLUE SCREEN OF DEATH(BSOD) - caused either by hotspot shield or not updated/corrupt graphic card driver
Posted (edited)
Informations taken from the attached txt file at the fifth post and added after the problem has been solved:
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Caused By Driver : ntkrnlpa.exe
File Description : NT Kernel & System
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Caused By Driver : dxgmms1.sys
File Description : DirectX Graphics MMS
Bug Check String : REFERENCE_BY_POINTER
Bug Check Code : 0x00000018
Bug Check String : DRIVER_POWER_STATE_FAILURE
Bug Check Code : 0x0000009f
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
the screen suddenly turns blue at any moment of time causing my computer to reboot.i have installed a new software called hotspot shield.is it due to the software?i doubt, because the program is not well written
System root: C:\Windows
Available physical memory: 2986 MB
CPU: Intel® Core i3-2310M CPU @ 2.10GHz
C: 146.39 GB
D: 195.31 GB
E: 195.31 GB
F: 161.52 GB
Internet Explorer: 10.0
Edited by xilolee
Added informations
Posted
then pls. tell me how to get the screenshot of BSOD becauz. i have not taken the screenshot before when it happened;or i have to wait for another BSOD to happen fo the screenshot?
Posted
There are three methods:
1.Take a picture of the blue screen with your camera if you can not remember and write down the error code, then send to us.
2.Uninstall the 'hotspot shield' on your pc, see whether blue screen show up as before. If it still show up, then we can tick off this program from the blue screen cause, vice versa.
3. Or you can enter C:\Users\Ivan\AppData\Local\CrashDumps  , find a file names 'dump', open it, and send it to us.
Posted
Hi,
Try following steps:
1, Run Wise Program Uninstaller to uninstall "hotspot shield"
2, Right-click Computer---Manage----Device Manage, find out Display adapters and double click it, ----Driver, can you see the Digital Signer as Microsoft Windows Hardware Compatibility Publisher?
If not, click Roll Back Driver to roll back to a early version.
If yes, click Uninstall, then re-install the driver. The driver version must be official and has Microsoft digital signer.  You can download driver from the graphic's providers website.
