Nu stiu cum so caracterizez
Please try the methods below.
Method 1: Run the internet explorer performance troubleshooter and check.
a)      Press Windows key + W to search Settings.
 B)    Type “Troubleshoot” without quotes and click on Troubleshooting.
c)      In the new windows click View all on the left pane.
d)      In the list of options, click on Internet Explorer Performance.
e)      Click Next and follow the on-screen instructions.
Method 2: Manage add-ons
Click the link and follow the steps “Manage add-ons in Internet Explorer”
http://windows.microsoft.com/en-US/internet-explorer/manage-add-ons#ie=ie-10
Check if the issue is fixed.  If not.
Method 3: Reset the Internet Explorer.
Click the link and follow the steps “How to reset Internet Explorer settings”
http://support.microsoft.com/kb/923737?wa=wsignin1.0
Disclaimer: The Reset Internet Explorer Settings feature might reset security settings or privacy settings that you added to the list of Trusted Sites. The Reset Internet
Explorer Settings feature might also reset parental control settings. We recommend that you note these sites before you use the Reset Internet Explorer Settings feature
Also I suggest you to install latest Windows updates.
http://windows.microsoft.com/en-US/windows-8/windows-update-faq
Hope the information helps.
Thanks.
Link to comment
