remco Posted August 25, 2013 Report Posted August 25, 2013 This window appears on my pc desktop every time the pc has booted. No cure found yet. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: F:\WINDOWS Available physical memory: 1023 MB CPU: AMD Athlon XP Drive Info: F: 74,21 GB Internet Explorer: 8.0
Config Posted August 26, 2013 Report Posted August 26, 2013 German to English: Svchost.exe Application ErrorThe instruction at "0x7c929af2" referenced memory at "0x00000010".The process "written" could not be performed on the memory.Click "OK" to exit the program.Click "Cancel" to debug the program. -------------- Please try the following steps: Step 1: Check if the issue persists in the safe mode and post back with the details. A description of the Safe Mode Boot options in Windows XP: http://forum.wisecleaner.com/index.php?/topic/1182-tips-to-start-the-computer-in-safe-mode-xp/ Step 2: If the issue does not persist in the safe mode then there is a possibility that some third party programs installed on the computer is causing the issue. How to configure Windows XP to start in a "clean boot" state: http://forum.wisecleaner.com/index.php?/topic/1183-tips-to-manually-start-windows-xp-with-a-clean-boot/
