18689478382 Posted August 22, 2013 Report Share Posted August 22, 2013 电脑太卡 Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 2047 MB CPU: Pentium® Dual-Core CPU E5800 @ 3.20GHz Drive Info: C: 114.75 GB D: 114.75 GB E: 114.74 GB F: 121.51 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
april Posted August 23, 2013 Report Share Posted August 23, 2013 We suggest you use Wise Care 365 or the last solution of Wise PC1stAid. Thanks. Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 23, 2013 Report Share Posted August 23, 2013 Could you tell me which game did you play? Usually, game effect has something to do with the hardware performance of the PC, such as CPU, memory, Graphics.etc. Recommended configuration or basic configuration will usually be provided when running every game. I f the effect is not manifest or even no effect after using Wise Care 365 and Wise PC 1stAid, please check if the configuration of your PC meets the requirement of this game Link to comment Share on other sites More sharing options...
