eazyep Posted August 21, 2013 Report Posted August 21, 2013 icons are missing in devices and printers. totally blank Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 6038 MB CPU: Intel® Core i5-2410M CPU @ 2.30GHz Drive Info: C: 581.42 GB Internet Explorer: 10.0
Config Posted August 23, 2013 Report Posted August 23, 2013 Hi! We assume that you were using an HP. Then plz try the following: IssueWhen you open the Devices and Printers window, the HP product icon is missing. However, the product is functioning correctly. Figure 1: Example HP product icon in the 'Devices and Printers' window SolutionIf the HP product icon is not displaying in Devices and Printers , you can view the HP product properties, print queue, and preferences by following these steps. On the Windows taskbar, click the Windows icon ( ), and then click Devices and Printers . The Devices and Printers windows opens. Under Devices , right-click on the computer icon. The device menu opens. On the menu, click one of the following options for the HP product. See what's printing : Lists the current print jobs for the HP product. Set as default printer : Set your HP product as the default printer. Printing preferences : Customize the options for your printouts. Printer properties : Lists the properties for your HP product. Delete print queue : Allows you to delete the printer driver from Devices and Printers . WARNING:If you delete the default printer, Windows 7 automatically assigns another default printer, unless there are no other printers installed in Windows 7. Figure 2: Location of HP product options on the computer menu
